Component: EBM004 GUI (Misc)
Author Matrix
Category Misc
EBM004_GUI component
Private non-release sub-component for the EBM004 digital temperature sensor.
Please click here to download the component source project: FC_Comp_Source_EBM004_GUI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM004_GUI.fcfx
ReadByte
ReadByte
Get the data from the MSB of a sensor register.
- BYTE Address
The address of the byte to return.
ReadFloat
ReadFloat
Get the temperature register value converted into an actual floating point temperature readng in Celcius.
- FLOAT Return
ReadInt
ReadInt
Get the complete 16bit integer value of the sensor's temperature register.
- BYTE Address
- INT Return
SetConsoleHandle
SetConsoleHandle
Pass the parent sensor's console handle to the GUI to allow opening of the console from the 'Console' button.
- HANDLE Handle
Handle of the console
SetMinMax
SetMinMax
Set the minimum and maximum temperature values that can be shown and set on the thermometer readout.
- FLOAT Min
Minimum Value
- FLOAT Max
Maximum Value
SetTemperature
SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
- FLOAT Temperature
Zero to one value - representing min-max of the sensor.
A text label to help you identify the component on the panel.
Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
Number of numbered divisions shown on the thermometer scale.
I2C Data
Choose whether the I2C data is shown as decimal or hexadecimal values.
