Component: UART Software (Timer) (Comms: Interface)
Author MatrixTSL
Category Comms: Interface
UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
UART_Timer_Example
CheckBuffer
CheckBuffer
Returns the number of values in the transmit or receive buffer
- BOOL Buffer
0=Transmit / 1=Receive
Initialises the UART component pins ready to send and receive data
ReceiveBinary16Bit
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
- BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
- UINT Timeout
Max amount of time in ms to wait between bytes
ReceiveBinary32Bit
ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
- BOOL MSBfirst
- UINT Timeout
- ULONG Return
ReceiveBinaryFloat
ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
- BOOL MSBfirst
- UINT Timeout
- FLOAT Return
ReceiveBytetArray
ReceiveBytetArray
Gets an array of values from the receive buffer. Returns number of values received.
- BYTE Values
- BYTE NumValues
- UINT Timeout
Time in milliseconds to wait for data
ReceiveChar
ReceiveChar
Attempts to receive a single packet from the UART interface.
- UINT Timeout
Time to wait in milliseconds for valid data before returning, 0=Dont wait, 255=Wait forever.
- INT Return
ReceiveFloat
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- UINT Timeout
Max time in ms to wait in between bytes
- BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
- FLOAT Return
ReceiveHexNumber
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- UINT Timeout
- BOOL IgnoreData
- BOOL Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG Return
ReceiveINTArray
ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT Data
Array to store the incoming data
- UINT NumValues
Maximum number of values to try and receive
- BOOL MSBfirst
- UINT Timeout
ReceiveNumber
ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- UINT Timeout
- BOOL IgnoreData
- LONG Return
ReceiveString
ReceiveString
Gets a string from the receive buffer
- UINT MaxChars
- UINT Timeout
- STRING Return
SendBinary16Bit
SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
- UINT Value
- BOOL MSBfirst
SendBinary32Bit
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG Value
- BOOL MSBfirst
SendBinaryFloat
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
- FLOAT Value
- BOOL MSBfirst
SendByteArray
SendByteArray
Sends an array of bytes to the transmit buffer
- BYTE Values
- BYTE NumValues
SendChar
SendChar
Sends out a single packet from the UART interface.
- INT Char
SendFloat
SendFloat
Sends a single float to the transmit buffer
- FLOAT Value
SendHexNumber
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG Number
- BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
- BOOL Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SendIntArray
SendIntArray
Sends an array of ints to the transmit buffer
- INT Data
- BYTE NumValues
- BOOL MSBfirst
SendNumber
SendNumber
Sends out a number as an ASCII String to the transmit buffer
- LONG Number
SendString
SendString
Sends an string to the transmit buffer
- STRING Data
UART_Timer_Process
UART_Timer_Process
Called as part of a timer interrupt at the specific UART baud rate.
Global Settings
Data Bits
Stop Bits
Use TX
Allows the Transmit pin to be enabled / disabled
Use RX
Allows the Receive pin to be enabled / disabled
Transmit Properties
Transmit Pin
Pin assigned to transmitting data
Transmit Buffer Size
Number of bytes that can be stored in the outgoing transmit buffer
API
Please click here to download the component source project: FC_Comp_Source_UART_Software_Timer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_Software_Timer.fcfx
