Component: MIAC Industrial (MIAC: Addon Modules)
Author
Category MIAC: Addon Modules
MIAC Industrial component
MIAC Industrial Addon component for MIAC System. Add (WIZ810MJ) TCP/IP or Webserver component to the panel to add functionality.
Please click here to download the component source project: FC_Comp_Source_ma_industrial.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ma_industrial.fcfx
AnalogInput
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
DigitalInput
DigitalInput
Read the value of a terminal
- BYTE Terminal
DigitalOutput
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
Initialize
Initialize
Forces a software reset on the module
LED_Control
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
MIAC_Module_GetAck
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Init
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_Message
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_PushData
- BYTE Data
MIAC_Module_RD
MIAC_Module_RD
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Return
MIAC_Module_SetData
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_WR
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
RS485_Initialize
RS485_Initialize
Initialize the parameters for the RS485 communication channel
- BYTE DataSize
Bit width, 8 or 9 bits
- INT BaudRate
RS485_Receive
RS485_Receive
Wait up to Timeout (mS) for a character to be received. Returns the character if successful, otherwise: 0x8000 Unexpected acknowledgment ID 0xa000 Insufficient data in acknowledgment 0xc000 Unexpected CAN ID acknowledgment 0xe000 Timeout, nothing received
- UINT Timeout
Timeout in mS
RS485_Send
RS485_Send
Send a character to RS485. Returns 0 for successful acknowledgment, otherwise: 0x8000 Unexpected acknowledgment ID 0xa000 Insufficient data in acknowledgment 0xc000 Unexpected CAN ID acknowledgment 0xe000 Timeout, no acknowledgment received
- INT Char
Module Type
Module Address
