Component: Pulse Oximeter (Max30100) (Environmental)
Category Environmental
Pulse Oximeter (Max30100) component
Sensor designed to monitor heart rate and pulse omimetry. Connected using an I2C bus.
Please click here to download the component source project: FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
Sets up the I2C bus ready for communications with the sensor IC. Must be called once before calling any of the other component macros. Applies the defauilt settings from the component properties.
ReadIR
ReadIR
Returns one of the FIFO IR readings from the last update
ReadRed
ReadRed
Returns one of the FIFO Red readings from the last update
SetHighResModeEnabled
- BYTE Enabled
SetLEDsCurrent
SetLEDsCurrent
- BYTE IR
Range: 0-15 / 0=0mA, 1=4mA, .., 14=46mA, 15=50mA
- BYTE Red
SetLEDsPulseWidth
SetLEDsPulseWidth
- BYTE PulseWidth
SetSamplingRate
SetSamplingRate
- BYTE SampleRate
Range: 0-7 / 0=50Hz, 1=100Hz, .., 6=800Hz, 7=1000Hz
Update
Update
Reads the sensor FIFO buffer and stores the readings into local RAM. Returns the number of samples read.
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Baud rate to be used
Sensor Defaults
Sample Rate
Sets the default sample rate
Pulse Width
Sets the default pulse width and bit depth of the sensor measurements
High Resolution Mode
Sets if the module defaults to high or low reolution mode
IR LED Current
Default current to drive the IR LED
Red LED Current
Default current to drive the Red LED
Simulate Comms
Allows the I2C communications to be simulated and interfaced via an API component to real world hardware.
