Component: Light Sensor (Grove 101020132) (101020132) (Light)
Category Light
Light Sensor (Grove 101020132) component
The Light sensor module is a simple analogue photo transistor. Used to detect the intensity of the indoor light.
Please click here to download the component source project: FC_Comp_Source_Light_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Light_Sensor.fcfx
GetAverageByte
GetAverageByte
Function call to read the ADC as a byte average sample over time
- BYTE NumSamples
- BYTE DelayUs
Number of micro seconds in between taking each sample
GetAverageInt
GetAverageInt
Function call to read the ADC as a full width average sample over time
- BYTE NumSamples
- BYTE DelayUs
GetByte
GetByte
Blocking call to read the ADC as a byte
GetInt
GetInt
Blocking call to read the ADC at full bit depth
GetString
GetString
Reads the ADC as a direct voltage and returns as as tring
- STRING Return
GetVoltage
GetVoltage
- FLOAT Return
Settings
VRef voltage
VRef option
Conversion speed
Aquisition cycles
Bit Depth
