Component: Injector (COM) (Test Injectors)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.2
Category Test Injectors
Injector (COM) component
Comms data injector to allow a COM port peripheral to be attached to a comms component. The component will forward any outgoing bytes to the COM port and forward any incoming bytes to the comms component. Useful for controlling hardware such as Bluetooth, RS232, USB to Serial, MODBUS...
Please click here to download the component source project: FC_Comp_Source_InjectorCOM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorCOM.fcfx
UARTBaud
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
UARTCheckRX
- BYTE Channel
UARTInitialise
UARTInitialise
- BYTE Channel
UARTReceive
UARTReceive
- BYTE Channel
UARTSend
UARTSend
- BYTE Channel
- BYTE Data
COM Injector Settings
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud rate passed to the COM port to control the rate of data in bits per second.
Timeout Value
Value to specify what is returned when no incoming receive data is present.
Receive Timeout
Maximum amount of time to wait in milliseconds before returning the timeout value
Show Console
