Component: Grove I2C Motor Driver (Mechatronics)
Category Mechatronics
Grove I2C Motor Driver component
A grove board based around the L298P motor driver IC allowing control of two DC motors or a single stepper motor.
Please click here to download the component source project: FC_Comp_Source_Grove_I2C_Motor_Driver.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Grove_I2C_Motor_Driver.fcfx
Frequency
Frequency
Set the frequency of PWM (cycle length = 510, system clock = 16MHz)
- BYTE FrequencySelection
1=31.372 KHz, 2=3.921 KHz, 3=490 Hz, 4=122 Hz, 5=30 Hz
Sets up the I2C ready for communications
Speed
Speed
Sets the speed of a motor.
- BYTE Motor
1=Motor1 / 2=Motor2
- INT Speed
Range: -255 to 255 where -255 = Full Backwards, 0=Stop, 255=Full Forwards
Stop
Stop
Stop one motor
- BYTE Motor
1 = Motor1 / 2 = Motor2
Communications
I2C Address
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Default Frequency
API
Specifies the API component on the panel to interact with to provide comms simulation.
