Component: Potentiometer (Analog Input)
Category Analog Input
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
Potentiometer Example
Using Fixed Voltage Reference
An example of a 0 to 1023 mV meter with a resolution of 1mv.
ADC using FVR
A PIC16F15324 is used since it has a Fixed Voltage Reference (FVR) register.
Bit0 and bit1 determine what the FVR is set at.
A line of C code is added to set the FVR to a gain of x1 = FVR of 1.024V:
FVRCON = 0b11000001;
With this setting, the Int value from ADC directly proportional voltage in mV.
E.g. a value of 732 = 732mV
Binary is used to make reading values a lot easier.
From the datasheet:
If you wanted to change the fixed voltage reference to 2.048V
Then change bit0 and bit1 of the C code to FVRCON = 0b11000010;
Filtering ADC Inputs
LPFilter
LPFilter2
Analogue Inputs Window
The Analogue inputs window available from the View ribbon, allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
Data Recorder
GetAverageByte
GetAverageByte
Read the ADC as a byte
- BYTE NumSamples
- BYTE DelayUs
GetAverageInt
GetAverageInt
Read the ADC at full bit depth
- BYTE NumSamples
- BYTE DelayUs
GetByte
GetByte
GetInt
GetInt
GetString
GetString
Reads the ADC as a direct voltage
- STRING Return
GetVoltage
GetVoltage
- FLOAT Return
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Retain Value
Component Label
LabelColour
Show Connection Label
Show Pin Value
Colour Style
Fill
Frame Outline
Frame Fill
Pointer Outline
Pointer Fill
Text
Tick Mark Outline
Tick Mark Fill
Cap Outline
Cap Fill
Main Image
Cap Image
Style
Type
