Component: Property Manager (Utility )
Category Utility
Property Manager component
Allows property values exposed to the user to be saved and loaded using an external file. Simplifies the process of storing and retreiving the property values. Also works with nested properties using the "::" syntax.
Load
Load
Loads the registered property values from the config file.
RegisterProperty
RegisterProperty
Registers a property to be saved or loaded. The property name should also include the component name e.g. Top level property - "PropVarName" Component property - "ComponentName::PropVarName"
- STRING PropertyVariable
Property variable exposed to the user, highlight property and variable is shown at the bottom of the window.
Save
Save
Saves the registered property values to the config file.
Filepath
Directory path on the system of where to store the file. $(srcdir) is the Flowcode project directory.
Filename
Show Dialogue On Load
Forces the user to check if they are sure before loading saved values.
Show Dialogue On Save
Forces the user to check if they are sure before overwriting previous values.
Please click here to download the component source project: FC_Comp_Source_PropertyManager.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_PropertyManager.fcsx
