Component: Data Transfer (API UART) ()
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.2
Category
Data Transfer (API UART) component
Comms data injector to allow a Serial UART peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical UART.
Please click here to download the component source project: FC_Comp_Source_InjectorSCADAUART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorSCADAUART.fcfx
ChangeState
ChangeState
Sets the state of the bus. SPI - Controls the chip select pin I2C - Controls the start/restart/stop status
- BYTE State
SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart
GetConsoleHandle
GetConsoleHandle
- HANDLE Return
InitialiseInjector
InitialiseInjector
- STRING InjectorName
RxByte
RxByte
TxByte
TxByte
- BYTE DataByte
SCADA Slave
BAUD Rate
Sets the data bit rate of the Serial UART. See the SCADA Slave UART Baud macro for valid values,
RS485 Direction Control
Allows an I/O pin to be automatically assigned when transmitting and receiving.
RS485 Properties
RS485 Pin Number
Digital I/O pin number to use for the RS485 data direction pin
TX Pin State
Decides the state of the RS485 data direction pin when transmitting data.
RX Pin State
Decides the state of the RS485 data direction pin when receiving data.
