Component: LTSR Current Transducer (Electrical)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author medelec35
Category Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Please click here to download the component source project: FC_Comp_Source_LTSR_Current_Transducer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LTSR_Current_Transducer.fcfx
Current
Current
- FLOAT Return
Device
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
