Component: GameCode (Misc Circuit)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author Jef De Bruyne
Category Misc Circuit
GameCode component
A small handheld device designed for creating embedded games. Complete with a 8 x 16 LED display, 4-Way DPAD with 4 additional push switches Buzzer, Vibration, MP3 Player, Potentiometer and Lithium battery management. Programmed via USB.
Please click here to download the component source project: FC_Comp_Source_GameCode_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GameCode_Master.fcfx
BatteryRead
BatteryRead
Read and return the voltage level of the battery in millivolt.
DisplayBrightness
DisplayBrightness
Control the brightness of the display.
- BYTE Value
Enter value from 0 to 15
DisplayClear
DisplayClear
Clear the display.
DisplayWrite
DisplayWrite
Write an array containing 16 bytes to the display to illuminate the corresponding dots. The index represents the line (Y-axis), starting from 0 for the uppermost line. The value of the byte represents the column (X-axis), with MSB the leftmost dot.
- BYTE Array
Index = line, Content (byte) = column
DisplayWriteNumber
DisplayWriteNumber
Show a number ranging from 000 to 999 on the display. Number is printed vertically.
- UINT Value
Enter a number from 0 to 999.
EEReadValue
EEReadValue
Retreives a value from none volitile memory
- BYTE Address
Address to write to, Range: 0-255
EEStoreValue
EEStoreValue
Saves a value to none volitile memory
- BYTE Address
- BYTE Value
Value to store, Range: 0-255
Initializes all present hardware and communication. Place this at the very start of your code.
LedsWrite
LedsWrite
Set the button-leds. MSB = leftmost led LSB = rightmost led
- BYTE Value
MSB = leftmost dot, LSB = rightmost dot
MP3GetStatus
MP3GetStatus
Returns the status of the MP3 module. 0 = module in sleep 1 = track is playing 2 = track is pauzed 3 = track is stopped
MP3PausePlayResetStop
Allows the current playing track to be paused, restarted or stopped.
- BYTE Mode
0=Pause, 1=Play, 2=Reset, 3=Stop
MP3PlayTrack
MP3PlayTrack
Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. "0001-anyname.mp3". Other folder track numbers should be 3 characters long e.g. "001-anyname.mp3".
- BYTE Directory
0=Root, 01=Folder "01" - 99=Folder "99", 100=Folder "MP3", 101=Advert
- UINT Track
Track number 1 = "001.mp3" / "0001.mp3"
MP3SendCommand
MP3SendCommand
Send commands to MP3 module. Check datasheet for info.
- BYTE Command
- BYTE Para1
- BYTE Para2
MP3SetVolume
MP3SetVolume
Sets the volume level for the MP3 module
- BYTE Volume
Range: 0 (min) - 30 (max)
PlayNote
PlayNote
Output a single note on the buzzer. Specify the desired frequency (Hz) and duration (ms).
- UINT Frequency
Sets the pitch for the note in Hz. Range 1-20000 Hz
- ULONG Duration
Time period to play the note for in milliseconds. Range 0-65535 ms
PotRead
PotRead
Read and return the value of the potentiometer. If desired, give the upper limit to scale the output value. Enter "MaxValue = 0" to skip scaling and get the byte value (0-255)
- UINT MaxValue
Scale the return value. Enter 0 to skip.
PwrLedSet
PwrLedSet
Control the PWR LED. 0 = red + green 1 = red 2 = green
- BYTE Value
0 = red + green, 1 = red, 2 = green
LED Colours
LED On
LED Off
Display Colours
On Colour
Off Colour
Background Colour
