Component: Colour Sensor V3 (Grove 101021133) (101021133) (Light)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Light
Colour Sensor V3 (Grove 101021133) component
Based on the color sensor VEML6040 with digital output I2C. senses red, green, blue, and white light and incorporates photodiodes, amplifiers, and analog / digital circuits into a single chip. Provides a spectrum matching real human eye responses.
CalculateLux
CalculateLux
Uses the RGB values stored in RAM from the last Sample to calculate the luminance in lux.
CalculateTemp
CalculateTemp
Uses the RGB values stored in RAM from the last Sample to calculate the colour temperature in degrees Kelvin.
DisableSensor
DisableSensor
Powers down the device to save power.
EnableSensor
EnableSensor
Powers up the device ready for taking colour readings.
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor. Returns 1 if the sensor is detected and responding to commands.
- BOOL Return
ReadDataChannel
ReadDataChannel
Returns the value of the selected colour channel from the last sample. The Red, Green and Blue channels have a colour filter to remove light of other colours. The Clear channel has no filter allowing the ambient light level to be easily collected.
- BYTE ColourChannel
Range: 0 to 3 - 0=Red, 1=Green, 2=Blue, 3=Clear
SampleSensor
SampleSensor
Reads the raw colour channels from the sensor and stores the readings into RAM to be collected by the ReadDataChannel macro.
SetIntegrationTime
SetIntegrationTime
Controls the integration time. 0 = 40mS / 1 = 80mS / 2 = 160mS / 3 = 320mS / 4 = 640mS / 5 = 1280mS
- BYTE Setting
Range: 0 to 5
Sensor Settings
Integration Time
Length of time period used to sample the sensor frequency (longer is more accurate)
I2C Settings
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Simulation Type
Selects the simulation type for the component. Component GUI - Interacts with the panel to sense the colour of a object in close proximity to the sensor. I2C Injector - Performs the I2C commands allowing you to connect an injector component or view and debug the I2C communications.
Please click here to download the component source project: FC_Comp_Source_Colour_Sensor_V3_I2C_Grove.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Colour_Sensor_V3_I2C_Grove.fcfx
