Component: Event Log (Runtime Tools)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Runtime Tools
Event Log component
A simulation component designed to create a simple log record of events in your SCADA system. Logs to a file and / or to a console tab including optional automated time stamp.
Please click here to download the component source project: FC_Comp_Source_EventLog.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EventLog.fcfx
LogEvent
LogEvent
Allows an event string to be logged
- STRING LogString
Log To Console
Log To File
Include Timestamp
Controls if a timestamp is appended to the start of the log string. Yes: Add timestamp to log string No: Leave log string as is
Console Properties
Console Name
Clear On Init
Selects if the contents of the console are maintained or wiped on runtime start. Yes: Console is automatically cleared No: Console is maintained and appended
File Properties
Log File
File to store the log data. Default: $(srcdir)log.txt $(srcdir) specifies the directory containing your Flowcode project file. log.txt specifies a file named log.txt If the file does not exist then it will be automatically created for you.
Clear On Init
Selects if the contents of the log file are maintained or wiped on runtime start. Yes: Log file is automatically cleared No: Log file is maintained and appended
Timestamp Properties
TimeStamp
US Date Format
Specifies the format of the date string. No - "DD/MM/YY" Yes - "MM/DD/YY"
