Component: RFID (EB052, RWD-MICODE) (Wireless)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author Matrix Ltd.
Version 2.0
Category Wireless
RFID (EB052, RWD-MICODE) component
Low level routines for controlling a RF Solutions RFID interface Allows communications between Mifare, ICode and HiTag type RFID tags. Also available in the form of the EB052 RFID E-block.
Please click here to download the component source project: FC_Comp_Source_RFID.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RFID.fcfx
Reading the status
The status of the RFID module is read using the "GetRFIDStatus" macro which returns a byte which is then displayed using the PORTB pins. RFID Status Status byte breakdown for Mifare.
Status byte breakdown for ICode.
Status byte breakdown for HiTag.
Status byte breakdown for EM Marin.
Reading and Writing Data
Example which talks to a ICode type card and allows the data to be read and written via a keypad. RFID Read/Write
Macro compatibility
Not all the macros can be used with all card types, here is a list of RFID transponder types and the macros that are compatible.
DecrementRFIDValue
DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
Needed for MIFARE Commands
FormatRFIDValue
FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
GetRFIDStatus
GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
GetRFIDTypeID
GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
GetRFIDUID
GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
IncrementRFIDValue
IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
ReadRFIDBlock
ReadRFIDBlock
Reads a block of information from the RFID device.
- BYTE Address
- BYTE Key_Type
ReadRFIDBuffer
ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
- BYTE Address
The address of the buffer 0 - 15
ReadRFIDUID
ReadRFIDUID
Reads a byte of data from the UID buffer.
- BYTE Address
The address of the buffer 0 - 7
StoreRFIDKey
StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
- BYTE Key
Key Location 0 - 31
- BYTE D0
Least significant byte of key
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
Most significant byte of key
TransferRFIDValue
TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
- BYTE Src
Page / Block
- BYTE Dst
Page / Block
- BYTE Key_Type
WriteRFIDBlock
WriteRFIDBlock
Writes a block of information to the RFID device.
- BYTE Address
Remote RFID Block Address.
- BYTE Key_Type
WriteRFIDBuffer
WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
- BYTE Address
- BYTE Data
The data to be stored in the buffer location 0 - 255.
WriteRFIDModule
WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
- BYTE Address
- BYTE Data
Card_Type
Baud Options
TX
RX
CTS
Console Columns
Data Source
