Component: Visi (4DSystems) (Comms: System)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author Matrix Ltd.
Version 2.0
Category Comms: System
Visi (4DSystems) component
A way of interacting with the VISI interface designed by 4D systems. VISI firmware must be pre-loaded onto the SD card connected to the display to allow everything to work correctly.
ChangeHWBaud
ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
- BYTE NewBaud
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
VisiReadByteFromMessage
Reads a byte from a succesful VisiReceive macro. Index: 0=Command, 1=ObjectID, 2=ObjectIndex, 3=ValueMSB, 4=ValueLSB
- BYTE Index
VisiReadObject
VisiReadObject
Reads the value from a specific Visi object. Returns 0 for a sucessful read. Use the VisiReadByteFromMessage macro to pull out the incoming data.
- BYTE ObjectID
- BYTE ObjectIndex
VisiReceive
VisiReceive
Waits for an incoming Visi Report Object or Report Event to be sent from the display. A detected incoming message returns 0 and can be read using the VisiReadByteFromMessage macro.
VisiWriteContrast
VisiWriteContrast
Updates the display contrast. Returns 0 for a succesful write operation.
- BYTE Contrast
Range 0-15, 0=Backlight Off
VisiWriteObject
VisiWriteObject
Writes a value to a specific Visi object. Returns 0 for a succesful write operation.
- BYTE ObjectID
- BYTE ObjectIndex
- UINT Value
VisiWriteString
VisiWriteString
Writes a string to a specific Visi object. Returns 0 for a succesful write operation.
- BYTE StringIndex
- STRING StringData
VisiWriteVolume
VisiWriteVolume
Updates the display volume. Returns 0 for a succesful write operation.
- BYTE Volume
Range 8-127
Comms Settings
Baud Options
TX
RX
Label shown on the communications flasher component
Console Columns
Data Source
Please click here to download the component source project: FC_Comp_Source_API_Display_Visi4D.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_Display_Visi4D.fcfx
