Component: Real Time Clock (MCP7940N) (Real Time Clock)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Real Time Clock
Real Time Clock (MCP7940N) component
Serial (I2C) Real Time Clock component for MCP7940N device. When used with a MIAC project this component gives access to the internal RTC (if fitted, depending upon model) and the component properties will be automatically configured.
Please click here to download the component source project: FC_Comp_Source_RTC_(MCP7940N).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RTC_(MCP7940N).fcfx
GetDate
GetDate
Returns the date as a string DDMMYY
- STRING Return
GetTime
GetTime
Returns the time as a string HHMMSS
- STRING Return
Initialises the component ready for I2C communications
ReadRegister
ReadRegister
Read and return the value of the RTC register at the given address
- BYTE address
SetDate
SetDate
Sets the date from a string DDMMYY
- STRING Date
SetTime
SetTime
Sets the time from a string HHMMSS
- STRING Time
WriteRegister
WriteRegister
Write the given data value to the RTC register at the given address
- BYTE address
- BYTE data
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
