Component: Input CSV (DSP Inputs)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Version 1.2
Category DSP Inputs
Input CSV component
Allows the values from a buffer to be collected directly from a CSV file. Either a value at a time or from an array.
Please click here to download the component source project: FC_Comp_Source_DSP_FileInput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_FileInput.fcfx
CloseFile
CloseFile
Closes a file
OpenFile
OpenFile
Opens a file ready for reading. Returns 1 if file opened correctly. Automatically called by the ReadValue/ReadArray macros with the default values set by the component properties if not already called by the program.
- STRING Filename
- BOOL Return
ReadArray
ReadArray
Reads an array of values to fill up the specified buffer. FAT component must be initialised before calling this macro. Returns 0 when we are at the end of the file, else returns 1.
- BOOL Return
ReadValue
ReadValue
Reads a value from the current row in the CSV file. FAT component must be initialised before calling this macro. Returns 0 when we are at the end of the file, else returns 1.
- BOOL Return
Buffer Size 0
Buffer Type 0
CSV File
LinkTo
Filename
Name of the file to read DSP data from.
Number of Outputs
The number of outputs the CSV reader can provide. Each output will be driven by the corresponding column of the CSV file.
End of File
Determines what happens when we hit the end of the input file. The return value from the ReadValue/ReadArray can be checked to allow the file end to be caught and actioned.
