Component: Button helper (Helpers)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Version 1.1
Category Helpers
Button helper component
A button overlay that allows any object to behave like a button
Please click here to download the component source project: FC_Comp_Source_buttonhelper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_buttonhelper.fcfx
Clear
Clear
Clears all objects from the lists This leaves no links for the button helper
GetState
GetState
Returns true if the button is depressed, else false
- BOOL Return
GetStateFor
GetStateFor
- HANDLE Target
- BOOL Return
GetTarget
GetTarget
Gets the target handle the property links to
- HANDLE Return
Register
Register
Adds the object to the list if not already there
- HANDLE Target
SetAutoReset
SetAutoReset
Sets the state of the auto-reset flag If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
- BOOL State
Set true to reset to off on sim stop, else false to retain state
SetAxis
SetAxis
Sets the movement axis as an Axis_... constant
- BYTE Axis
Movement axis to set to, default 4
SetAxisFor
SetAxisFor
- HANDLE Target
- BYTE Axis
SetDisabledPos
SetDisabledPos
Sets the position of the released button
- HANDLE PositionHandle
A handle to the position of the depressed location
SetDisabledPosFor
SetDisabledPosFor
Sets the disabled position for an object
- HANDLE Target
- HANDLE Position
SetEnabledPos
SetEnabledPos
Sets the position of the depressed button
SetEnabledPosFor
SetEnabledPosFor
Sets the enabled position for an object
- HANDLE Target
- HANDLE Position
SetLatching
SetLatching
Sets whether the button is depressed when the mouse is released
- BOOL Enabled
SetLatchingFor
SetLatchingFor
- HANDLE Target
- BOOL Enabled
SetMode
SetMode
Sets the animation mode for the button
- BYTE Mode
0=User, 1=Up/Down, 2 = Lever
SetModeFor
SetModeFor
- HANDLE Target
The target object, 0 for 'set default'
- BYTE Mode
SetMovement
SetMovement
Sets the movement in units or PI/16 steps for the button
- FLOAT Move
Movement to set to - default is 4
SetMovementFor
SetMovementFor
- HANDLE Target
- FLOAT Move
Movement to set to, default 4
SetNotify
SetNotify
Sets the object to notify when the button is pressed or released
- HANDLE Handle
The handle of the object - 0 to use the caller object
- ULONG Ident
The identifier to send in the System.Notify message
SetPivotPos
SetPivotPos
Sets the position of the object the lever rotates around
SetPivotPosFor
SetPivotPosFor
Sets the position the lever rotates around for an object
- HANDLE Target
- HANDLE Position
Unregister
Unregister
Removes the object to the list if present
- HANDLE Target
Host component
Lever pivot
