| Author
Matrix TSL
| Version
3.0
| Category
Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
20, 1.0, 26-07-24, BR, Added pallet buffer allowing 4,8-bit bitmaps to function
Here is an example that will scan for bitmap files in the root of the SD card and display them on a graphical display.
Bitmap Drawer File Demo
The zip file contains the Flowcode project as well as some example bitmap image files taken from Pixabay.
Place the bitmap files on the root of the SD card for the embedded hardware to work.
Display_BMP
Display_BMP
| Draws the bitmap image onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING
Filename
| Bitmap file to open from current directory on SD card 8.3 format
- UINT
X
| X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT
Y
| Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE
Orientation
| 0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE
Transparency
| 0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE
Flip
| 0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
- BYTE
Display_BMP_Fast
Display_BMP_Fast
| Draws the bitmap image onto the display at the corrdinates X and Y. Speeds up drawing by not assigning X/Y coordinate for each pixel. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING
Filename
- UINT
X
- UINT
Y
- BOOL
Mode
| 0=RowByRow, 1=FullWindow(Y Flipped)
- BOOL
Orientation
| 0=Default, 1=Rotated 90 Degrees (only works with Mode 0)
- BYTE
Display_BMP_Fast_Partial
| Draws a partial bitmap image onto the display at the coordinates X and Y. Speeds up drawing by not assigning X/Y coordinate for each pixel. Allows drawing a percentage of the bitmap width and height from a specified side (top/bottom, left/right). Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING
Filename
- UINT
X
- UINT
Y
- BYTE
WidthPercent
| Percentage of bitmap width to draw. Range: 0-100
- BYTE
HeightPercent
| Percentage of bitmap height to draw. Range: 0-100
- BYTE
HorizontalSide
| Which horizontal side to draw from: 0=Left, 1=Right
- BYTE
VerticalSide
| Which vertical side to draw from: 0=Top, 1=Bottom
- BOOL
Mode
- BOOL
Orientation
- BYTE
Display_BMP_Partial
Display_BMP_Partial
| Draws a partial bitmap image onto the display at the coordinates X and Y. Allows drawing a percentage of the bitmap width and height from a specified side (top/bottom, left/right). Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING
Filename
- UINT
X
- UINT
Y
- BYTE
WidthPercent
- BYTE
HeightPercent
- BYTE
HorizontalSide
- BYTE
VerticalSide
- BYTE
Orientation
- BYTE
Transparency
- BYTE
Flip
- BYTE
Display_Scaled_BMP
Display_Scaled_BMP
| Draws the bitmap image onto the display at the corrdinates X and Y. Scales the bitmap to the specified width and height. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING
Filename
- UINT
X
- UINT
Y
- UINT
Width
| The size in pixels to draw the bitmap image
- UINT
Height
- BYTE
Orientation
- BYTE
Transparency
- BYTE
Flip
- BYTE
Display_Scaled_BMP_Fast
| Draws the bitmap image onto the display at the corrdinates X and Y. Scales the bitmap to the specified width and height. Speeds up drawing by not assigning X/Y coordinate for each pixel. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- STRING
Filename
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BOOL
Mode
- BOOL
Orientation
- BYTE
GetHeight
GetHeight
| Returns the height of the loaded bitmap file in pixels.
- STRING
Filename
| The filename of the bitmap we want to measure
- UINT
GetWidth
GetWidth
| Returns the width of the loaded bitmap file in pixels.
- STRING
Filename
- UINT
SetTransparentColour
| Sets the transparency colour, the colour that is not drawn when transparency is enabled.
- BYTE
R
- BYTE
G
- BYTE
B
GLCD LinkTo
File LinkTo
ColourDisplay
| Automatically detects if the graphical LCD object is colour or monochrome
Pallet Buffer
| Dedicates an area of RAM to be used as a pallet buffer allowing 4-bit and 8-bit bitmaps to be drawn efficiently. No: No additional RAM is used and only 1-bit and 24-bit bitmaps are supported. Yes: 768 additional bytes of RAM are used and 1-bit, 4-bit, 8-bit and 24-bit bitmaps are supported.
Use File Index
| Allows multiple files to be accessed at once.
Use File Path
| Allows a path to be specified for accessing bitmap files. e.g. Images\
Please click here to download the component source project: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
