Component: Object Helper ( Data)
Author MatrixTSL
Version 0.1
Category Data
Object Helper component
Component to help when dealing with Javascript objects.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Object.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Object.fcsx
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
Web Weather Example
GetKeys
GetKeys
Returns a list of the JavaScript object's keys
- HANDLE Object
The JavaSctipt object
- HANDLE Return
GetValue
GetValue
Gets the value for a key in a JavaScript object
- HANDLE Object
The JavaScript object
- STRING sKey
The key name
- HANDLE Return
JSONToObject
JSONToObject
Converts a JSON string to a JavaScript object
- STRING Text
The JSON string to convert to a JavaScript object
- HANDLE Return
NumberToObject
NumberToObject
Converts a number to a JavaScript object
- LONG Var
The number to convert to a JavaSctipt object
- HANDLE Return
ObjectToFloat
ObjectToFloat
Converts an object to a floating point value
- HANDLE Object
- FLOAT Return
ObjectToInteger
ObjectToInteger
Converts an object to an integer
- HANDLE Object
- LONG Return
ObjectToJSON
ObjectToJSON
Converts an object to a JSON string
- HANDLE Object
- STRING Return
ObjectToNumber
ObjectToNumber
Converts an object to a number
- HANDLE Object
- FLOAT Return
ObjectToString
ObjectToString
Converts an object to a string
- HANDLE Object
- STRING Return
SetValue
SetValue
Sets the value of a key in a JavaScript object. Returns true if the key already exists.
- HANDLE Object
- STRING sKey
The key name
- HANDLE Value
The value for the key
- BOOL Return
StringToObject
StringToObject
Converts a string to a JavaScript object
- STRING Var
The string to convert to a JavaScript object
- HANDLE Return
