| Author
Matrix TSL
| Version
10.0
| Category
Analog Input
Joystick (Sparkfun Quiic) 2D component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
10, 10.0, 04-12-24, MW,Icon edited so compatible with dark theme
ChangeI2CAddress
ChangeI2CAddress
| Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE
NewAddress
| Range: 8 to 119 or 0x08 - 0x77
- BOOL
CheckButton
| Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
- BOOL
| Initialises the I2C bus ready for communications with the module.
ReadAxis
ReadAxis
| Reads a single axis of the joystick and returns as a signed integer value.
- BYTE
Axis
| Range 0-1 Where 0=X, 1=Y
- BOOL
Type
| 0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
- INT
ReadButton
| Checks to see if the button is currently pressed
- BOOL
SimMoveThumbStick
SimMoveThumbStick
- FLOAT
X
- FLOAT
Y
- HANDLE
Component
Return To Center
| Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
Limits
X Min
X Max
Device Address
Theme
Box Colour
Shaft Colour
Knob Colour
Style
Style
| Outline line style
| Channel selection
Baud Select
| Baud rate option selector
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
