Component: RTD (MAX31865) (Environmental)
Category Environmental
RTD (MAX31865) component
Component to interface the MAX31865 RTD-to-digital converter IC. Uses a standard SPI interface to connect to the IC and measure RTD resistance / temperature. Compatible with PT100 and PT1000 temperature sensors.
Version information
1, 1.0, 23-12-24, BR, Initial MAX31865 RTD component implementation
AutoConvert
AutoConvert
Enables or disables automatic continuous conversion.
- BYTE Enable
0 = One-shot, 1 = Continuous
ClearFault
ClearFault
Clears any latched fault flags in the MAX31865.
EnableBias
EnableBias
Enables or disables the MAX31865 bias current.
- BYTE Enable
0 = Off, 1 = On
Initialises the SPI bus and basic MAX31865 configuration.
ReadFault
ReadFault
Reads the MAX31865 fault status register.
ReadTemperature
ReadTemperature
Performs a sample and returns temperature in Degrees C.
- FLOAT Return
Sample
Sample
Performs a single MAX31865 conversion and returns the raw sensor reading.
SetNotchFilter
SetNotchFilter
Sets the notch filter to 50Hz (1) or 60Hz (0).
- BYTE Mode
0 = 50Hz, 1 = 60Hz
SetWires
SetWires
Sets the RTD wiring mode (2/3/4-wire).
- BYTE Wires
2, 3 or 4 wires
RTD Properties
RTD Type
Selects the RTD type used with the MAX31865.
Reference Resistor (Ohms)
Reference resistor value used on the MAX31865 breakout (default 430 Ohms).
Notch Filter
Bias Current
Auto Convert
RTD Wiring Mode
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
SPI Data Out pin (MOSI).
MISO
SPI Data In pin (MISO).
CLK
SPI Clock pin (SCK).
CS / SS
Chip Select / Slave Select pin used to enable the MAX31865.
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMAX31865.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMAX31865.fcfx
