Component: Barometer (BMP280 / Grove 101020192) (101020192) (Environmental)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 8.0
Category Environmental
Barometer (BMP280 / Grove 101020192) component
Barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 ?C.
Version information
7,7.0, 27-06-24, MW, Fixed ReadPressureFloatSim as Get and Read value was set to (2).
7,7.0, 27-06-24, MW, Removed all  references to humidity as not present within BMP280.
8,8.0, 27-06-24, MW, Added Ev_initialise API, setting the pressure of the library sensor to an inital value of 300.
Altitude
Altitude
Calculates the altitude based on difference between actual pressure and the pressure at the sea level P0=1013.25 hPa.
- FLOAT Return
Forced_Read
Forced_Read
I2C_Read_Register
I2C_Read_Register
Reads a byte value from a register on the device
- BYTE Address
I2C_Write_Register
I2C_Write_Register
Writes a byte value to a register on the device
- BYTE Address
- BYTE Value
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected.
ReadPressureFloat
ReadPressureFloat
Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value.
- FLOAT Return
ReadTemperatureFloat
- FLOAT Return
Reset
Reset
Resets the device
I2C Properties
Slave Address
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Sensor Properties
Compensation
Compensation formulas in double precision floating point or 32 bit fixed point
Pressure Oversampling
Temperature Oversampling
Mode
Standby Normal Mode (ms)
Filter Coefficient
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_Barometer_Grove_BMP280.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Barometer_Grove_BMP280.fcfx
