Component: Digital Potentiometer (MCP41XX / MCP42XX) (Analog Output)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Analog Output
Digital Potentiometer (MCP41XX / MCP42XX) component
The MCP41XX and MCP42XX device range supports up to 2 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Please click here to download the component source project: FC_Comp_Source_MCP41xx_42xx_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP41xx_42xx_Digital_Pot.fcfx
DecrementWiper
DecrementWiper
Decrements a single volatile wiper value
- BYTE Index
Range: 0-1
IncrementWiper
IncrementWiper
Increments a single volatile wiper value
- BYTE Index
Range: 0-1
Startup the SPI peripheral ready for communications.
ReadAddress
ReadAddress
Reads a value from one of the registers on the device
- BYTE Address
Range: 0-15
SetWiper
SetWiper
Sets the value of a single wiper
- BYTE Index
Range: 0-1
- UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
- BOOL MemoryType
0=Volatile, 1=Nonvolatile
WriteAddress
WriteAddress
Writes a value to one of the registers on the device
- BYTE Address
Range: 0-15
- UINT Value
Range: 0-256
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Device Properties
Number of Outputs
Number of Taps
Simulate Comms
