Component: Bluetooth v2 (EB024, Generic AT) (Wireless)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author Matrix Ltd.
Version 2.1
Category Wireless
Bluetooth v2 (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware channel.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_V2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_V2.fcfx
Making a device discoverable
Example program to set up the Bluetooth module to be discoverable with a pair key. Any data received is then output onto the LCD component. You can connect to the Bluetooth device using a PC with Bluetooth connection and using software such as Flowcode 6, RealTerm or HyperTerminal. Alternatively you can connect using a smart phone running a terminal emulator app or via another embedded Bluetooth board. Bluetooth Discover Script 1 contains the AT commands to setup the Bluetooth device to be discoverable with pair key "1234".
Searching for a device
Example program to scan for local discoverable Bluetooth devices. For each device found the MAC address is displayed on to the LCD. Bluetooth Inquiry
Connecting to a device
Example program to connect to a specific Bluetooth device address and send data to the device. Bluetooth Connect The device MAC address is specified using the "CreateCommandString" and "SendCommand" macros.
Sets up the Bluetooth module. Returns 0 for OK, 255 for no reply and 254 for command fail.
ReadString
ReadString
Copies the incoming data from the data string array to a local string variable.
- BYTE NumBytes
- STRING Return
ReceiveByte
ReceiveByte
Receives a single data byte from the Bluetooth module. 0xFF signifies no data available.
- BYTE Timeout
Amount of time to wait in milliseconds 0=Wait forever
RestoreFactorySettings
Restores the factory settings to firmware using the AT&F* command. Returns 0 to indicate success
SaveSettings
SaveSettings
Saves the current settings to firmware using the AT&W command followed by the ATZ command. Returns 0 to indicate success
SendByte
SendByte
Sends a single data byte out to the Bluetooth module.
- BYTE Data
SendCommand
SendCommand
Sends a command string to the Bluetooth module. 0 = Command sent ok, 255 = No Reply
- STRING Command
- BYTE SendCR
- BYTE DiscardReply
0=Do not touch the reply, 1=Wait for reply and remove from buffer
SendScript
SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
SendString
SendString
Sends a string to the Bluetooth module.
- STRING Command
- BYTE SendCR
SetMode
SetMode
Sets the bluetooth mode to be discoverable and or connectable. Returns 0 for success.
- BYTE Discoverable
0 = Not Discoverable, 1 = Discoverable
- BYTE Connectable
0 = Not Connectable, 1 = Connectable
SetPairKey
SetPairKey
Sets the 4 digit Bluetooth pair key based on a string of numbers. e.g. "1234" Returns 0 to indicate success
- STRING PairKey
Key to use as the Pair key, e.g. "1234" or "0000"
Bluetooth Settings
String Array Size
Amount of RAM memory to dedicate to receiving responses from the BT module. Default 40
Expect Echo
Sets if we expect an echo of any data we send out to the GSM modem. Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
Device Name
Sets the friendly name of the Bluetooth device.
Pair Key
Restore Defaults
Is the Bluetooth module reset to factory settings at startup?
Discoverable
Is the Bluetooth module discoverable by default?
Connectable
Is the Bluetooth module connectable by default?
Script Count
Maximum number of scripts to store in the device's ROM
Script1
ASCII based AT command data stored in ROM and used when sending script 1
Baud Options
TX
RX
Use Flow Control
Reset Pin
Textual label shown on the component I/O flasher
Console Columns
Data Source
