Component: LED MultiColour Tri (5mm, PCB) (LED)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category LED
LED MultiColour Tri (5mm, PCB) component
An industry standard 5mm diameter tri-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_tricolour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_tricolour.fcfx
Tricolour LEDs generally have four pins and come in both common anode and common cathode configurations and must be wired to suit. The tricolour LED component should have a property allowing you to configure which LED type your using.
Six pin tricolour LEDs can simply be treated as three individual standards LEDs.
The series resistor acts to protect each individual LED from damage due to excess current. The value of resistor used can be changed based on the brightness of the LED and power consumption. Usually the three colour LEDs have different characteristics from each other so a different protection resistor should be provided for each LED to balance the LEDs output.
LED Resistor Calculator Tool
LEDOff
LEDOff
Switches off the LED
LEDOneOn
LEDOneOn
Switches on LED one, other LEDs switched off.
LEDSetState
LEDSetState
Controls the state of the LED. 0=Off / 1=LED Colour 1 / 2=LED Colour 2 / 3=LED Colour 1 + 2 4=LED Colour 3 / 5=LED Colour 1 + 3 / 6=LED Colour 2 + 3 7=LED Colour 1 + 2 + 3
- BYTE State
Range 0-7 0=All Off, 7 = All On
LEDThreeOn
LEDThreeOn
Switches on LED three, other LEDs switched off.
LEDTwoOn
LEDTwoOn
Switches on LED two, other LEDs switched off.
Pin
LED Pin 1
Pin2
LED Pin 2
Pin3
LED Pin 3
Polarity
Color
The color of the LED when pin1 is turned on and pin2 is turned off.
Color2
The color of the LED when pin1 is turned off and pin2 is turned on.
Color3
Trim Leads
Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
