Component: File (ESP32 SDMode) (File)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author Matrix Ltd.
Version 9.9
Category File
File (ESP32 SDMode) component
File component allowing access to read and write files on an SD card using the ESP32 SD Mode IO allowing for high speed data transfer using 1-bit or 4-bit SD access.
Version information
9, 9.0, 04-03-25, MW, Changed tooltips from Not implemented on the RPI to Not implemented on the ESP32
AppendByteArrayToFile
- BYTE Data
- UINT Length
AppendByteToFile
AppendByteToFile
- BYTE Data
AppendFloatArrayToFile
Adds a binary float array to the end of the file. Returns 0 for success.
- FLOAT Data
Binary data array to append to the file
- UINT Length
Number of values to append
AppendINTArrayToFile
Adds a binary INT array to the end of the file. Returns 0 for success.
- UINT Data
- UINT Length
- BOOL MSBFirst
0=LSB then MSB, 1=MSB then LSB
AppendLongArrayToFile
Adds a binary Long array to the end of the file. Returns 0 for success.
- ULONG Data
- UINT Length
- BOOL MSBFirst
AppendStringToFile
AppendStringToFile
- STRING Data_String
CloseFile
CloseFile
CreateFile
CreateFile
- STRING Filename
DeleteFile
DeleteFile
- STRING Filename
Starts up the SD card interface and checks to see if a card is compatible. Returns: 0=OK, 255=No Card, 254=File System Fail
MoveToNextFileSector
- BYTE ForceNextSector
OpenFile
OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
- STRING Filename
8.3 filename of the file we are trying to open e.g. "file.txt"
OpenFolder
OpenFolder
- STRING Folder_Name
ReadByteArrayFromFile
Reads a binary byte array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- BYTE Data
- UINT Length
ReadByteFromFile
ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
ReadByteFromIndex
ReadByteFromIndex
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
- ULONG Address
ReadFileLength
ReadFileLength
- INT Return
ReadFileSize
ReadFileSize
Reads the entire size of the current file in bytes.
- ULONG Return
ReadFloatArrayFromFile
Reads a binary Float array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- FLOAT Data
Data variable to populate with data
- UINT Length
Number of values to read
- BOOL MSBFirst
ReadINTArrayFromFile
Reads a binary INT array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- UINT Data
- UINT Length
- BOOL MSBFirst
ReadLongArrayFromFile
Reads a binary Long array from the currently open file. Auto increments the position in the file. Returns the number of values read.
- ULONG Data
- UINT Length
- BOOL MSBFirst
ReadStringFromFile
ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
- UINT NumBytes
Maximum number of bytes to attempt to read
- BYTE EndChar
Ends the string if the value specified is found, default is 0
- STRING Return
SetFileIndex
SetFileIndex
- BYTE File_Index
Range: 0 to 4
Uninitialise
Uninitialise
Terminates connection to the SD card, unmounts the SD card and disabled the SD peripheral.
WriteByteToBuffer
WriteByteToBuffer
- UINT Address
- BYTE Data
WriteFileSector
WriteFileSector
Frequency
File Count
Number of simultaneous files we want to access.
SD Mode
Buffer Size
Number of bytes to use as a read buffer to speed up file access.
Directory Size
Number of bytes to use as a directory buffer to track the current directory.
Pins
CLK
CMD
D0
D1
D2
D3
Sim Root Folder
The directory used by the simulation to look for files.
Please click here to download the component source project: FC_Comp_Source_File_ESP32_SDMode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_ESP32_SDMode.fcfx
