Component: LED MultiColour Bi (5mm, PCB) (LED)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category LED
LED MultiColour Bi (5mm, PCB) component
An industry standard 5mm diameter bi-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_bicolour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_bicolour.fcfx
A Bi Colour LED should be connected between two microcontroller I/O pins as shown below.
LED Resistor Calculator Tool
LEDOff
LEDOff
Switches off the LED
LEDOneOn
LEDOneOn
Switches on LED one
LEDSetState
LEDSetState
Controls the state of the LED. 0=Off 1=LED Colour 1 2=LED Colour 2
- BYTE State
0=Off, 1=Pin1 High & Pin2 Low, 2=Pin1 Low & Pin2 High
LEDTwoOn
LEDTwoOn
Switches on LED two
Pin
LED Pin 1
Pin2
LED Pin 2
Color
The color of the LED when pin1 is turned on and pin2 is turned off.
Color2
The color of the LED when pin1 is turned off and pin2 is turned on.
Trim Leads
Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
