Component: Keypad (BL0138) (BL0138) (E-blocks 2)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category E-blocks 2
Keypad (BL0138) component
Keypad component to drive the E-blocks 2 BL0138 Keypad board. Provides twelve individual raster scanned switches.
Version information
9, 1.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise 10, 1.0, 08-05-25, BR, Adjusted Pins and Port to use inherited base properties
GetAscii
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetIndex
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
GetNumber
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetString
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
- STRING Return
WaitPressed
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
WaitReleased
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Output Mode
Port
Please click here to download the component source project: FC_Comp_Source_EB_KeyPad_BL0138.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_KeyPad_BL0138.fcfx
