Component: ADC (AD7680) (Analog Input)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Analog Input
ADC (AD7680) component
16-bit external ADC connected to the microcontroller using SPI.
Please click here to download the component source project: FC_Comp_Source_ExternalADC_AD7680.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_AD7680.fcfx
Overview
The AD7680 is a 2.5V to 5.5V SPI compatible, successive approximation analogue to digital converter (ADC).
The reference for the AD7680 is taken internally from VDD
Pin reference from the datasheet:
This example reads the voltage on the AD7680 Vin and converts the ADC results into a voltage. For the result to be correct, you must change the Voltage variable to match the supply voltage.
AD7680 Demo
Circuit Diagram
Initialise the SPI bus ready for communications,
SampleADC
SampleADC
Reads the ADC and returns the reading as an unsigned 16-bit value. Range: 0-65535 / 0=0V / 65535=VCC
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
