Component: ADC QUAD + DAC (PCF8591) (Analog Input)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Analog Input
ADC QUAD + DAC (PCF8591) component
An I2C device allowing for up to 4 x 8-bit analogue inputs as well as 1 x 8-bit analogue output. Up to 8 devices can be used together ona signel I2C bus.
Please click here to download the component source project: FC_Comp_Source_External_ADC4_DAC1_PCF8591.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_External_ADC4_DAC1_PCF8591.fcfx
EnableDAC
EnableDAC
Enables and Disables the DAC output, Default Disabled.
- BOOL Enabled
0=Disabled, 1=Enabled
Sets up the I2C bus ready for communications with the device.
SampleADC
SampleADC
Performs a single ADC sample on the selected ADC channel
- BYTE Channel
Range: 0-3
SetupADC
SetupADC
Configures how the ADC inputs are wired
- BYTE Configuration
Range: 0-3, Default 0
WriteDAC
WriteDAC
Writes a value to the digital to analogue output.
- BYTE Value
Device Address
The address pins are used to allow up to 8 individual devices to be connected onto an I2C bus. Sets the state of the pins.
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
Allows the communications to be simulated overriding the value on the panel slider controls.
