Component: LED Matrix (Parallel) (LEDs)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category LEDs
LED Matrix (Parallel) component
LED Matrix component designed to work using multiple data pins and a single clock pin. Each LED on the display can be controlled in a chain by setting the data appropriatley and then generating the appropriate amount of clock pulses.
Please click here to download the component source project: FC_Comp_Source_LED_Matrix_Parrallel.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Matrix_Parrallel.fcfx
Parallel LED matrix example schematic showing 16 LEDs connected using two octal buffer ICs. Data connections to the microcontroller are Data0-Data7, LED_EN, Reset and Clock.
Each clock pulse transfers the output state to the next LED so Data0 goes to LED R0D0 and LED R0D0 goes to LED R1D0 etc.
Example Program ledmatrixp Note. to allow the simulation to run smoothly ensure that the simulation speed is set to normal and you may also want to enable hardware acceleration using the Global Options.
Example Panel Display
ClearLEDs
ClearLEDs
Sets all of the LEDs in the matrix to the off state.
DisplayString
DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
- STRING Data
Data string to display on the LEDs
- UINT Animation_Delay
Delay in milliseconds between writing to the next column
- BYTE Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
- BYTE Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
StrobeHigh
StrobeHigh
Sets the strobe pin high. Strobing controls the LED brightness and does not apply to simulation.
StrobeLow
StrobeLow
Sets the strobe pin low. Strobing controls the LED brightness and does not apply to simulation.
WriteColumn
WriteColumn
Allows a single column of data to be inserted, Acts to shift the rest of the columns across by one.
- BYTE Data
Data to display on the column of LEDs
LED Type
Active high outputs a logic 1 to set the LED and logic 0 to clear the LED. Active low outputs a logic 0 to set the LED and logic 1 to clear the LED
Row Count
Number of LED rows
Column Count
Number of LED columns
LED Count
Total number of LEDs in the component
Flip Display
Allows the column and text data sent to the display to be flipped
D0
Data0 pin which is used to pass the input LED0 value
D1
Data1 pin which is used to pass the input LED1 value
D2
Data2 pin which is used to pass the input LED2 value
D3
Data3 pin which is used to pass the input LED3 value
D4
Data4 pin which is used to pass the input LED4 value
D5
Data5 pin which is used to pass the input LED5 value
D6
Data6 pin which is used to pass the input LED6 value
D7
Data7 pin which is used to pass the input LED7 value
Clock
Clock pin used to clock the external buffer IC's
Strobe
Strobe pin used to control the master display state, strobed at high speed using PWM to set the brightness.
Colours
On Color
Simulated colour of the LEDs when switched On
Off Color
Simulated colour of the LEDs when switched Off
Row Spacing
Simulation row spacing
Column Spacing
Simulation column spacing
Width
Simulation LED width
Height
Simulated LED height
Depth
Simulated LED Depth (3D environments only)
LED Shape
Simulated LED basic shape
Redraw LEDs
Simulated LED redraw option, display will not be updated until the redraw is set to Yes. Automatically revers back to No after the refresh has been performed.
