Component: WLAN (EB069, WIZ610wi) (Misc)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author Matrix Ltd.
Version 1.3
Category Misc
WLAN (EB069, WIZ610wi) component
Wireless LAN component designed to work with the WIZ610wi module from Wiznet. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN.fcfx
CheckForPageRequests
ConnectToSSID
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 0 if successful.
- STRING SSID
- STRING Key
DisableCommandMode
DisableCommandMode
Exits command mode
EnableCommandMode
EnableCommandMode
Enables command mode. Must be called before commands are issued.
GetInValue
GetInValue
- BYTE index
Index of the request paramter, starting at zero.
- STRING Return
GetReply
GetReply
Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT
Initialise the device with the property data. Returns 0 if successful
ReadConnectionStatus
Checks the connection status. Returns 0 if not connected, 1 if connected.
ReceiveIncoming
ReceiveIncoming
Returns the received data string
- STRING Return
SendCommand
SendCommand
Sends the given command and returns the reply status. (See GetReply for return values)
- STRING Command
SendString
SendString
Sends the given Text. Appends a CR/LF pair of characters it CrLf is true.
- STRING Text
- BYTE CrLf
Send_Embedded_HTML_Page1
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page4
SetOutValue
SetOutValue
- BYTE index
- STRING value
IP Address
IP 0
First number in IP address - e.g. xxx.168.1.1
IP 1
Second number in IP address - e.g. 192.xxx.1.1
IP 2
Third number in IP address - e.g. 192.168.xxx.1
IP 3
Fourth number in IP address - e.g. 192.168.1.xxx
Subnet Mask
Mask 0
First number in Subnet mask - e.g. xxx.255.255.0
Mask 1
Second number in Subnet mask - e.g. 255.xxx.255.0
Mask 2
Third number in Subnet mask - e.g. 255.255.xxx.0
Mask 3
Fourth number in Subnet mask - e.g. 255.255.255.xxx
Gateway IP
Gateway 0
First number from IP address used as the gateway to the internet e.g. xxx.168.1.1
Gateway 1
Second number from IP address used as the gateway to the internet e.g. 192.xxx.1.1
Gateway 2
Third number from IP address used as the gateway to the internet e.g. 192.168.xxx.1
Gateway 3
Fourth number from IP address used as the gateway to the internet e.g. 192.168.1.xxx
Trigger
WLAN module trigger pin connection
Reset
WLAN module reset pin connection
UART
WLAN module UART channel selection
Tx
WLAN module UART data transmit pin. Connects to receive pin on WLAN module.
Rx
WLAN module UART data receive pin. Connects to transmit pin on WLAN module.
SSID
Wireless network identifier string
SSID Broadcast
Decides if the network is detectable by a nearby Wifi device.
Server Port
Port number which is being monitored by the server, for starndard webpages port 80 is the default. To specify a non standard port you can enter the custom port number in the URL after a colon like this. 192.168.1.1:8080 - here we use 8080 as an alternative port.
WLAN Mode
Decides if the WLAN module is configured as a end device (connects to another wifi router) Or as an access point (allowing other wifi devices to connect to it)
DHCP
Controls if we are assigning IPs to any joing wifi devices or if we are using a fixed IP based system.
DHCP Pool Start IP Address
Start IP 0
Minimum IP address that can be generated for a joining device under DHCP.
Start IP 1
Start IP 2
Start IP 3
DHCP Pool End IP Address
End IP 0
Maximum IP address that can be generated for a joining device under DHCP.
End IP 1
End IP 2
End IP 3
Security
Decides if the security if untouched or reset to open. Security settings can be assigned using the Wiznet control web interface which is built into the modules.
Configures the Wifi data channel, setting to auto will allow the device to scan for the best channel for your area and the surounding wifi devices.
Data Rate
The data rate to try and acheive with the wifi connection.
Tx Power
The amount of power to use when transmitting signals to other wifi devices.
HTML Source
Max Web Pages
Maximum number of individual webpages we can serve up with the component.
Web Page Timeout
Number of cycles to try and send / receive a webpage before timing out.
Name Page 1
HTML name of webpage 1
HTML Page 1
HTML content for webpage 1
Name Page 2
HTML name of webpage 2
HTML Page 2
HTML content for webpage 2
Name Page 3
HTML name of webpage 3
HTML Page 3
HTML content for webpage 3
Name Page 4
HTML name of webpage 4
HTML Page 4
HTML content for webpage 4
