Component: TCP/IP (BL0187) (E-blocks 2)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 2.3
Category E-blocks 2
TCP/IP component
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_TCPIP_BL0187.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_BL0187.fcfx
ControlLEDs
ControlLEDs
Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly.
- BYTE Mode
0=Off, 1=On, 2=Auto
CreateIPSocket
CreateIPSocket
- BYTE Channel
Specifies the communications channel 0-3
- BYTE Protocol
Specifies which IP protocol to use
- BYTE Broadcast
Allows broadcast type packets to be sent and received
CreateMACSocket
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE Promiscuous
Receive everything (1) or just data bound for your MAC (0)
- BYTE Broadcast
Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE Error
Allowsmessages with errors to be accepted (1) or rejected (0)
CreateTCPSocket
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE Channel
- UINT Src_Port
Port Number
CreateUDPSocket
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE Channel
- UINT Src_Port
Port Number
DHCP_Setup
DHCP_Setup
DNS_Lookup
DNS_Lookup
Resolve the URL into an IP address via the DNS server. Returns non-zero if successful
- STRING URL
URL address string
- BYTE IP
Returned IPv4 address
GetLocalIP
GetLocalIP
Gets the local IP address
- BYTE IP
4-byte Array to store the IP address
GetLocalMAC
GetLocalMAC
Gets the local MAC address
- BYTE MAC
6-byte Array to store the MAC address
Initialises the SPI connection to the TCPIP module and sets up some initial values. Flashes the LEDs on and off twice to confirm SPI comms are active. LEDs are then configured to auto functionality.
ReadRegister
ReadRegister
Reads the value from a single register onboard the ENC28J60 module.
- BYTE Address
RxDataAvailable
RxDataAvailable
Check if data has been received. A non-zero return value indicates that data is available. This macro should be called regularly as it also processess supporting network traffic.
- BYTE Channel
RxDataSize
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE Channel
RxFlushData
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE Channel
RxMatchMyIP
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE Channel
RxMatchMyMAC
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE Channel
RxMatch_2_Bytes
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
Specifies the value of the first byte
- BYTE Byte2
Specifies the value of the second byte
RxMatch_4_Bytes
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
Specifies the value of the third byte
- BYTE Byte4
Specifies the value of the fourth byte
RxMatch_6_Bytes
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
- BYTE Byte5
Specifies the value of the fifth byte
- BYTE Byte6
Specifies the value of the sixth byte
RxReadByte
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
RxReadHeader
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE Channel
- BYTE Idx
Specifies the byte index to return
RxReadString
RxReadString
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
- BYTE Length
- STRING Return
RxSkipBytes
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE Channel
- BYTE Count
Specifies how many bytes to skip
RxStart
RxStart
Move the received buffer read pointer back to the start
- BYTE Channel
SetDestination
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer.
- BYTE Channel
- BYTE IP
- UINT Port
Destination Port
SetGateway
SetGateway
This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE IP0
First Byte of IP address
- BYTE IP1
Second Byte of IP address
- BYTE IP2
Third Byte of IP address
- BYTE IP3
Fourth Byte of IP address
SetLocalIP
SetLocalIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE IP0
- BYTE IP1
- BYTE IP2
- BYTE IP3
SetMACAddress
SetMACAddress
Allows the MAC Address specified in the component properties to be overridden. The MAC Address will revert back to the MAC specified in the component properties as part of the initialise macro.
- BYTE MAC0
MAC Address Parameter
- BYTE MAC1
- BYTE MAC2
- BYTE MAC3
- BYTE MAC4
- BYTE MAC5
SetSubnetMask
SetSubnetMask
This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE IP0
- BYTE IP1
- BYTE IP2
- BYTE IP3
TCP_Close
TCP_Close
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
TCP_Connect
TCP_Connect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- STRING URL
URL or IPv4 address
- UINT Dst_Port
Destination Port
TxEnd
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE Channel
TxSendByte
TxSendByte
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE Channel
- BYTE Data
Data byte to append to Tx buffer.
TxSendMyIP
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE Channel
TxSendMyMAC
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE Channel
TxSendString
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE Channel
- STRING Data
- BYTE Length
TxStart
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE Channel
WriteRegister
WriteRegister
Writes a value to a single register onboard the ENC28J60 module.
- BYTE Address
- BYTE Data
TCP IP Specifics
Server Port
Sets the server's TCP/IP port address which is used to filter incoming TCP packets.
Buffer Size
Number of bytes to use for the transmit and receive buffer, we actually use this +1 to allow for a null termination. 8-bit PICs should set this to 255 to allow compilation to succeed. Other devices can have larger buffers. Default = 500
SPI Settings
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Reset Pin
LED Flash
When enabled the socket LEDs will flash on/off 500ms. Useful for SPI check.
Auto DHCP
When enabled the Initialisation will also include DHCP setup to auto configure settings.
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
IP Address
IP0
IP1
IP2
IP3
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
Sim Type
Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
SPI Simulation
API
