Component: Temp / Humidity (DHT22) (Environmental)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.2
Category Environmental
Temp / Humidity (DHT22) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
Please click here to download the component source project: FC_Comp_Source_DHT22.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DHT22.fcfx
Example Program showing how to sample the DHT22 sensor and show the temperature and humidity on an LCD. DHT22 Example
GetHumidityFloat
GetHumidityFloat
Gets the humidity returned by calling SampleSensor as a floating point number. If humidity is 15.8 % then this function would return 15.8.
- FLOAT Return
GetHumidityReal
GetHumidityReal
Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8.
- INT Return
GetHumidityString
GetHumidityString
Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8".
- STRING Return
GetHumidityWhole
GetHumidityWhole
Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15.
- INT Return
GetTempFloat
GetTempFloat
Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8.
- FLOAT Return
GetTempReal
GetTempReal
Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8.
- INT Return
GetTempString
GetTempString
Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8".
- STRING Return
GetTempWhole
GetTempWhole
Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15.
- INT Return
SampleSensor
SampleSensor
Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error.
SIG Pin
Microcontroller I/O Pin connected to the DHT11 sensor data pin.
Use Checksum
The checksum value is used to ensure the data being received is correct. Yes = Only receive data if checksum is correct No = Ignore checksum
Advanced Settings
Clock Adjustment
On 8-bit PIC devices the timings can be a little tight as slower clock speeds and so we implement an adjustment factor to allow the sensor to function. Auto mode will attempt to automatically calculate a correct adjustment factor. Manual mode will allow you to set your own adjustment factor.
