| Author
Matrix TSL
| Version
1.0
| Category
Environmental
Barometer (MS5637) component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 0 to 30 Bar. Temperature range -20 to +85 °C.
Please click here to download the component source project: FC_Comp_Source_Pressure_Sensor_MS5637.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_MS5637.fcfx
| Stes up the I2C bus and initialises the termperature sensor ready for use.
ReadPROM
ReadPROM
| Reads a single 16-bit value from the PROM calibration data.
- BYTE
Address
| Range 0-6
- UINT
ReadPressureFloat
ReadPressureFloat
| Reads the pressure as a floating point value in Bars. Resultion sets the return bit value and conversion time. Calls the ReadPressureRaw function and then converts to a meaningful value.
- BYTE
Resolution
| Range 0-5
- FLOAT
ReadPressureRaw
ReadPressureRaw
| Reads the pressure as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.11mBar / 1=0.062mBar / 2=0.039mBar 3=0.028mBar / 4=0.021mBar / 5=0.016mBar
- BYTE
Resolution
| Range 0-5
- ULONG
ReadTemperatureFloat
| Reads the temperature as a floating point value in °C. Resultion sets the return bit value and conversion time. Calls the ReadTemperatureRaw function and then converts to a meaningful value.
- BYTE
Resolution
| Range 0-5
- FLOAT
ReadTemperatureRaw
ReadTemperatureRaw
| Reads the temperature as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.012°C / 1=0.009°C / 2=0.006°C 3=0.004°C / 4=0.003°C / 5=0.002°C
- BYTE
Resolution
| Range 0-5
- LONG
Reset
Reset
| Resets the device
I2C Properties
| Channel selection
SDA
SCL
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
Simulate Comms
| Allows the simulation data to come from the panel GUI or relayed via an injector component.
