Component: Bluetooth BLE (ESP32 SPP Server) (Wireless)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Category Wireless
Bluetooth BLE (ESP32 SPP Server) component
Bluetooth BLE server component designed to run on a ESP32 providing GATT SPP functionality. BT BLE functionality must be switched on via the sdkconfig file.
This component requires the Bluetooth and Bluedroid libraries from the ESP32 IPE.
If you get this error when compiling: esp_bt.h: No such file or directory
Then you may not have Bluetooth enabled.
To fix this navigate to C:\FC_ESP\mtx<chiptype>_sdkconfig\
Then run menuconfig.bat to open the configuration editor.
Goto Component Config -> Bluetooth
Check the item Bluetooth.
Then go into Bluedroid Options and ensure the Enable BLE 4.2 features near the bottom is ticked.
Save and exit and then re-compile 🙂
CheckConnectionStatus
Checks to see if the Bluetooth device is connected. Returns 1 if connected.
- BOOL Return
Starts up the Bluetooth communications SPP service.
ReceiveArray
ReceiveArray
Attempts to receive an array of bytes from the bluetooth serial port. Returns the number of bytes received.
- BYTE Data
Buffer to place received data into
- UINT MaxBytes
Max number of bytes to try and read within the time
- UINT Timeout
Number of ms to wait for incoming data
ReceiveByte
ReceiveByte
Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured
- UINT Timeout
ReceiveCount
ReceiveCount
Collects the number of bytes currently stored in the receive buffer.
ReceiveINTArray
ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT Data
Array to store the incoming data
- BYTE NumValues
Maximum number of values to try and receive
- BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveString
ReceiveString
Attempts to receive a string of characters from the Bluetooth SPP. Terminates on timeout, on receiving the MaxBytes or on receiving a '\n' character
- UINT MaxBytes
- UINT Timeout
- STRING Return
SendArray
SendArray
Sends an array of bytes to the Bluetooth serial connection
- BYTE Data
Data Array to send
- UINT NumBytes
Number of bytes to send
SendByte
SendByte
Sends a byte to the Bluetooth serial connection
- BYTE Data
SendINTArray
SendINTArray
Sends an array of 16-bit integers to the Bluetooth serial connection
- UINT Data
Data Array to send
- UINT NumValues
- BOOL MSBFirst
SendString
SendString
Sends a string to the Bluetooth serial connection
- STRING Data
Data Array to send
Uninitialise
Uninitialise
Shots down the Bluetooth communications SPP service.
Device Name
Sets the Bluetooth device friendly name. Max 19 characters.
Receive Buffer
Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
Service UUID
16-bit value that identifies the custom “Simple SPP” service so scanners know the device supports that feature.
Characteristic UUID
16-bit value that describes the single characteristic that carries the serial-like data flow (reads, writes, notifications).
Data Receive Interrupt
Verbose Debug
When enabled debug messages will be placed onto UART CH1 which is generally connected to via a Serial to USB IC to pipe messages back to the host PC.
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Server.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Server.fcfx
