Component: Output CSV (DSP Outputs)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA;"" to "class="mtx-class-propfolder"")
Version 1.2
Category DSP Outputs
Output CSV component
Allows the values from a buffer to be output directly into a .CSV format file. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_FileOutput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_FileOutput.fcfx
CloseFile
CloseFile
Closes a file
OpenFile
OpenFile
Opens a file ready for writing. Returns 1 if file opened OK. Automatically called by the WriteValue/WriteArray macros with the default values set by the component properties if not already called by the program.
- STRING Filename
Filename, must be an 8.3 formatted filename in embedded.
- BOOL ExistingData
0=KeepAndAppend, 1=Clear
- BOOL Return
WriteArray
WriteArray
Writes a buffer of values from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro.
WriteValue
WriteValue
Writes a single value from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro.
Connect To 0
CSV File
LinkTo
Number of Inputs
The number of inputs the multiplexer can switch between.
Filename
Name of the file to write DSP data to.
Existing Data
Decides what to do when opening a file that already exists.
