Component: Data Queue to Bits (DSP Inputs)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Inputs |
Data Queue to Bits component
Allows data to be loaded into a buffer and then output a bit at a time into the DSP system. Useful for things like communications where data is modulated and sent out a bit at a time.
Please click here to download the component source project: FC_Comp_Source_DSP_DataToBits.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_DataToBits.fcfx
CountQueueData
| CountQueueData | |
| Returns the number of data bytes/bits remaining in the queue. The bit count includes start/stop bits. | |
| CountBits | |
| 0=Return Byte Count, 1=Return Bit Count | |
FetchNextDataBit
| FetchNextDataBit | |
| Gets the next stored bit from the data queue. If the data queue is empty then returns the default state. | |
QueueByte
| QueueByte | |
| Adds a single byte value to the data buffer. | |
| Data | |
QueueByteArray
| QueueByteArray | |
| Adds an array of byte values to the data buffer. | |
| Data | |
| Count | |
QueueFloat
| QueueFloat | |
| Adds a single float value to the buffer. A 32-bit Float value occupies 4-bytes in the buffer. | |
| Data | |
QueueFloatArray
| QueueFloatArray | |
| Adds an array of float values to the data buffer. A 32-bit Float value occupies 4-bytes in the buffer. | |
| Data | |
| Count | |
QueueInt
| QueueInt | |
| Adds a single integer value to the data buffer. A 16-bit integer value occupies 2-bytes in the buffer. | |
| Data | |
QueueIntArray
| QueueIntArray | |
| Adds an array of integer values to the data buffer. A 16-bit integer value occupies 2-bytes in the buffer. | |
| Data | |
| Count | |
QueueLong
| QueueLong | |
| Adds a single long value to the data buffer. A 32-bit integer value occupies 4-bytes in the buffer. | |
| Data | |
QueueLongArray
| QueueLongArray | |
| Adds an array of long values to the data buffer. A 32-bit integer value occupies 4-bytes in the buffer. | |
| Data | |
| Count | |
QueueString
| QueueString | |
| Adds an string of characters to the data buffer. | |
| Data | |
