| Author
Matrix TSL
| Version
10.0
| Category
Comms: Networking
TCP/IP (W5500) component
TCP/IP component designed to work with the W5500 device used on the ETH WIZ Click
10, 0.0, 23-06-25, MW, Fixed a bug wihtin DHCP_Run that's causing compiler error with ESP32
HTTP Server
Simple example showing the W5500 component being used stand alone to create a web server.
W5500 Webserver
Network Comms
Here are some examples using the Network Communication component linked to the W5500 component.
NetworkComms W5500 Client
NetworkComms W5500 Webserver
CreateIPSocket
CreateIPSocket
| Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE
| Specifies the communications channel 0-3
- BYTE
Protocol
| Specifies which IP protocol to use
- BYTE
Broadcast
| Allows broadcast type packets to be sent and received
- BYTE
CreateMACSocket
CreateMACSocket
| This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
| Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
| Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
| Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
CreateTCPSocket
CreateTCPSocket
| This macro creates a socket for sending and receiving TCP data.
- BYTE
- UINT
Src_Port
| Port Number
- BYTE
CreateUDPSocket
CreateUDPSocket
| This macro creates a socket for sending and receiving UDP data.
- BYTE
- UINT
Src_Port
| Port Number
- BYTE
DHCP_CheckLease
DHCP_CheckLease
| Call once per second from your main loop when DHCP is enabled. Decrements the T1 renewal timer and when it expires attempts a unicast renewal, falling back to full rediscovery if the renewal fails. Returns: 0=lease OK, 2=renewed, 3=rebind failed, 4=rebind succeeded.
- BYTE
DHCP_Run
DHCP_Run
| Advances the DHCP state machine by one step and returns 0. States: 0=send DISCOVER; 1=wait for OFFER (type 2), timeout on miss; 2=wait for ACK (type 5) then advance to state 3 (leased); 3=leased, no-op (DHCP_CheckLease handles renewal); 4=renewal REQUEST sent, advance to 5; 5=wait for renewal ACK (type 5) or NAK/timeout back to 0. Called automatically by Initialise during startup. To force renegotiation: set DHCP_State=0, DHCP_Timeout=0, then call this macro in a polling loop until DHCP_State reaches 3 or DHCP_Timeout exceeds 1000.
- BYTE
DNS_GetHostByName
DNS_GetHostByName
| Resolves a hostname to an IPv4 address using the configured DNS server. Opens a UDP socket on the specified channel, sends a type-A query, waits up to ~2 seconds for a response, then parses the answer. Returns 1 on success with DNS_ResolvedIP populated, or 0 on timeout or any error.
- BYTE
| UDP socket channel to use (0-3). Must not conflict with DHCP channel.
- STRING
Hostname
| URL to try and resolve e.g. "Flowcode.co.uk"
- BYTE
DNS_GetResolvedIP
DNS_GetResolvedIP
| Returns the specified byte (index 0-3) of the IP address resolved by the most recent successful DNS_GetHostByName call.
- BYTE
Idx
| IP byte index 0-3.
- BYTE
DNS_GetServer
DNS_GetServer
| Returns the specified byte (index 0-3) of the configured DNS server IP address.
- BYTE
Idx
| IP byte index 0-3.
- BYTE
GetIPString
GetIPString
| Formats one of the DHCP-assigned network addresses as a null-terminated dotted-decimal ASCII string (e.g. "192.168.1.100") and writes it into Output. Selection: 0=assigned IP, 1=subnet mask, 2=gateway, 3=DNS server. Output must be at least 16 bytes.
- BYTE
Selection
| Which address: 0=IP, 1=Subnet, 2=Gateway, 3=DNS
- STRING
Output
| Caller-supplied buffer of at least 16 bytes; receives the formatted string
GetSocketStatus
GetSocketStatus
| This returns the state of the requested channel's socket.
- BYTE
- BYTE
| Resets and initialises the W5500 IC. Sets up the gateway address, subnet mask, device IP address and device MAC address. This macro must be called before any other TCP_IP component macros. Returns 1 to indicate successful communication.
- BYTE
MIAC_Module_GetData
MIAC_Module_GetData
| Internal. Returns one byte from the response buffer of the most recently polled MIAC industrial module.
- BYTE
Index
| Zero-based index of the byte to retrieve from the MIAC response buffer
- BYTE
MIAC_Module_Message
MIAC_Module_Message
| Internal. Sends a command message to a MIAC industrial module over the CAN-style serial bus and waits for an acknowledgement.
- UINT
CAN_ID
| CAN bus identifier of the target MIAC module
- UINT
CMD_ID
| Command identifier sent to the module
- BYTE
MIAC_Module_PushData
| Internal. Appends a byte to the outgoing data buffer used by the next MIAC_Module_Message call.
- BYTE
Data
| Byte to append to the outgoing MIAC data buffer
MIAC_Module_SetData
MIAC_Module_SetData
| Internal. Sends a command packet containing up to six data bytes to a connected MIAC industrial add-on module.
- BYTE
Count
| Number of data bytes to include in the message (0-6)
- BYTE
D0
| First data byte
- BYTE
D1
| Second data byte (unused if Count is less than 2)
- BYTE
D2
| Third data byte (unused if Count is less than 3)
- BYTE
D3
| Fourth data byte (unused if Count is less than 4)
- BYTE
D4
| Fifth data byte (unused if Count is less than 5)
- BYTE
D5
| Sixth data byte (unused if Count is less than 6)
RxDataAvailable
RxDataAvailable
| This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE
- BYTE
RxDataSize
RxDataSize
| This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- UINT
RxFlushData
RxFlushData
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
RxMatchMyIP
RxMatchMyIP
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
RxMatchMyMAC
RxMatchMyMAC
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
RxMatch_2_Bytes
RxMatch_2_Bytes
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
| Specifies the value of the first byte
- BYTE
Byte2
| Specifies the value of the second byte
- BYTE
RxMatch_4_Bytes
RxMatch_4_Bytes
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
| Specifies the value of the third byte
- BYTE
Byte4
| Specifies the value of the fourth byte
- BYTE
RxMatch_6_Bytes
RxMatch_6_Bytes
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
| Specifies the value of the fifth byte
- BYTE
Byte6
| Specifies the value of the sixth byte
- BYTE
RxReadArray
RxReadArray
| A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Data
| Destination byte array to receive the data
- UINT
Count
| Number of bytes to read from the receive buffer
RxReadByte
RxReadByte
- BYTE
- BYTE
RxReadHeader
| Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
| Specifies the byte index to return
- BYTE
RxReadString
RxReadString
| A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
| Maximum number of characters to read
- STRING
RxSkipBytes
RxSkipBytes
| Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
| Specifies how many bytes to skip
SetDestination
SetDestination
| This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE
- BYTE
Dst_IP0
| Specifies the first byte of an IP address
- BYTE
Dst_IP1
| Specifies the second byte of an IP address
- BYTE
Dst_IP2
| Specifies the third byte of an IP address
- BYTE
Dst_IP3
| Specifies the fourth byte of an IP address
- UINT
Dst_Port
| Destination Port
- BYTE
SetGateway
SetGateway
| This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
| First Byte of IP address
- BYTE
IP1
| Second Byte of IP address
- BYTE
IP2
| Third Byte of IP address
- BYTE
IP3
| Fourth Byte of IP address
SetMACAddress
SetMACAddress
| This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
- BYTE
MAC0
| First Byte of address
- BYTE
MAC1
| Second Byte of address
- BYTE
MAC2
| Third Byte of address
- BYTE
MAC3
| Fourth Byte of address
- BYTE
MAC4
- BYTE
MAC5
| Fifth Byte of address
SetMyIP
SetMyIP
| This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
SetSubnetMask
SetSubnetMask
| This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TCPClose
TCPClose
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
TCPConnect
TCPConnect
| This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
| Destination Port
- BYTE
TCPListen
TCPListen
| This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE
TxEnd
TxEnd
| Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
TxSendArray
TxSendArray
| This macro fills the specified channel's transmit buffer with data.
- BYTE
- BYTE
Data
| Data byte to append to Tx buffer.
- UINT
Count
| Number of bytes to transmit
TxSendByte
TxSendByte
- BYTE
- BYTE
Data
TxSendMyIP
TxSendMyIP
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
TxSendMyMAC
TxSendMyMAC
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
TxSendString
TxSendString
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE
- STRING
Data
- BYTE
Length
| Number of characters to transmit
TxStart
TxStart
| This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
DHCP
| Enable DHCP to automatically obtain IP address, subnet mask and gateway from a DHCP server. When enabled, the IP Address, Subnet Mask and Gateway IP properties are not used.
Gateway IP
Gateway0
| First octet of the default gateway IP address (e.g. 192 in 192.168.1.1). Ignored when DHCP is enabled.
Gateway1
| Second octet of the default gateway IP address. Ignored when DHCP is enabled.
Gateway2
| Third octet of the default gateway IP address. Ignored when DHCP is enabled.
Gateway3
| Fourth octet of the default gateway IP address (e.g. 1 in 192.168.1.1). Ignored when DHCP is enabled.
Subnet Mask
Subnet0
| First octet of the subnet mask (e.g. 255 for 255.255.255.0). Ignored when DHCP is enabled.
Subnet1
| Second octet of the subnet mask (e.g. 255 for 255.255.255.0). Ignored when DHCP is enabled.
Subnet2
| Third octet of the subnet mask. Ignored when DHCP is enabled.
Subnet3
| Fourth octet of the subnet mask (e.g. 0 for 255.255.255.0). Ignored when DHCP is enabled.
IP Address
IP0
| First octet of the static IP address (e.g. 192 in 192.168.1.100). Ignored when DHCP is enabled.
IP1
| Second octet of the static IP address. Ignored when DHCP is enabled.
IP2
| Third octet of the static IP address. Ignored when DHCP is enabled.
IP3
| Fourth octet of the static IP address (e.g. 100 in 192.168.1.100). Ignored when DHCP is enabled.
DNS Server
DNS0
| First octet of the DNS server IP address (e.g. 8 in 8.8.8.8). Used in static IP mode; also acts as fallback if DHCP does not provide a DNS server.
DNS1
| Second octet of the DNS server IP address (e.g. 8 in 8.8.8.8).
DNS2
| Third octet of the DNS server IP address (e.g. 8 in 8.8.8.8).
DNS3
| Fourth octet of the DNS server IP address (e.g. 8 in 8.8.8.8). Google Public DNS default.
MAC Address
MAC0
| First byte of the Ethernet MAC address (e.g. 0x00). Must be unique per device. The LSB must be 0 (unicast).
MAC1
| Second byte of the Ethernet MAC address (e.g. 0x08).
MAC2
| Third byte of the Ethernet MAC address (e.g. 0xDC - Matrix TSL OUI).
MAC3
| Fourth byte of the Ethernet MAC address.
MAC4
| Fifth byte of the Ethernet MAC address.
MAC5
| Sixth byte of the Ethernet MAC address. Change this to make each device unique.
| Display label for this component instance on the Flowcode panel.
Sim Type
| Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
TCP Simulation
Network Interface
| List of network interfaces connected to the PC. Sets which interface we are communicating via.
Please click here to download the component source project: FC_Comp_Source_TCPIP_W5500.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_W5500.fcfx
