Component: ST3215 Servo Motor (Mechatronics)
Revision as of 14:09, 2 September 2026 by Wiki bot (talk | contribs)
Version 2.0
Category Mechatronics
ST3215 Servo Motor component
Control ST3215 servo motors via serial UART communication using the STS protocol.
ChangeBaudrate
ChangeBaudrate
Change the servo baud rate. Baud rate values: 0=9600, 1=57600, 2=115200, 3=1000000. EEPROM must be unlocked.
- BYTE ServoID
Servo ID
- BYTE Baudrate
Baud rate value: 0=9600, 1=57600, 2=115200, 3=1000000
- BOOL Return
ChangeID
ChangeID
Change the servo ID. New ID must be 0-253. EEPROM must be unlocked. Note: New ID takes effect after power cycle.
- BYTE ServoID
Current servo ID
- BYTE NewID
New servo ID (0-253)
- BOOL Return
DefineMiddle
DefineMiddle
Define the 2048 position by setting torque to 128.
- BYTE ServoID
Servo ID
- BOOL Return
IsMoving
IsMoving
Check if the servo is currently moving. Returns True if moving, False otherwise.
- BYTE ServoID
Servo ID
- BOOL Return
ListServos
ListServos
Scan and return a list of all responsive servos. Returns number of servos found.
- BYTE ServoList
Array to store found servo IDs
- BYTE MaxCount
Max number of servos to try and return. 0=Don't limit
LockEEPROM
LockEEPROM
Lock EEPROM to prevent writes from being saved after power loss. IMPORTANT: Use the NEW servo ID after ChangeID.
- BYTE ServoID
Servo ID (use NEW ID after ChangeID)
- BOOL Return
PingServo
PingServo
Check if a servo is responding. Returns True if successful, False otherwise.
- BYTE ServoID
Servo ID to ping (0-253)
- BOOL Return
ReadAcceleration
ReadAcceleration
Read current acceleration value in steps per second squared.
- BYTE ServoID
Servo ID
ReadAngle
ReadAngle
Read current position of servo. Returns position in steps (0-4095).
- BYTE ServoID
Servo ID
- FLOAT Return
ReadCorrection
ReadCorrection
Read position correction value in steps.
- BYTE ServoID
Servo ID
- INT Return
ReadCurrent
ReadCurrent
Read current in milliamps (6.5mA resolution). Returns current / 6.5.
- BYTE ServoID
Servo ID
ReadID
ReadID
Read the servo ID from EEPROM. Returns the stored ID value.
- BYTE ServoID
Servo ID to query
ReadLoad
ReadLoad
Read motor load in percentage. Returns load percentage.
- BYTE ServoID
Servo ID
ReadMode
ReadMode
Read current operational mode. Returns: 0=position, 1=speed, 2=PWM, 3=step
- BYTE ServoID
Servo ID
ReadPosition
ReadPosition
- BYTE ServoID
Servo ID
- INT Return
ReadSpeed
ReadSpeed
Read current speed of servo. Returns speed in steps per second.
- BYTE ServoID
Servo ID
ReadStatus
ReadStatus
Read servo status flags. Returns status byte with bits: Voltage, Sensor, Temperature, Current, Angle, Overload
- BYTE ServoID
Servo ID
ReadTemperature
ReadTemperature
Read temperature in degrees Celsius.
- BYTE ServoID
Servo ID
ReadToolMode
ReadToolMode
Read current RA3 tool mode. Returns: 0=unassigned, 1=vacuum, 2=gripper, 3=pen
- BYTE ServoID
Servo ID
ReadTorqueLimit
ReadTorqueLimit
Read torque limit value (0-1000).
- BYTE ServoID
Servo ID
ReadVoltage
ReadVoltage
Read voltage in volts (0.1V resolution). Returns voltage * 10.
- BYTE ServoID
Servo ID
Rotate
Rotate
Rotate servo continuously in specified direction. Speed range: 50-1000. Direction: 0=forward, 1=reverse.
- BYTE ServoID
Servo ID
- UINT Speed
Rotation speed (50-1000)
- BYTE Direction
- BOOL Return
SetAcceleration
SetAcceleration
Set servo acceleration in steps per second squared.
- BYTE ServoID
Servo ID
- BYTE Acceleration
Acceleration value (0-254)
- BOOL Return
SetAngle
SetAngle
Move servo to a target angle. Angle range: -180 to 180 degrees.
- BYTE ServoID
Servo ID
- FLOAT Angle
- BOOL Return
SetCorrection
SetCorrection
Set position correction value in steps. Adds correction to position.
- BYTE ServoID
Servo ID
- INT Correction
Correction value in steps
- BOOL Return
SetMode
SetMode
Set operational mode. Mode: 0=position, 1=speed, 2=PWM, 3=step
- BYTE ServoID
Servo ID
- BYTE Mode
- BOOL Return
SetPosition
SetPosition
Move servo to a target position. Position range: -30719 to 30719 steps.
- BYTE ServoID
Servo ID
- UINT Position
Target position in steps (0 to 4095)
- BOOL Return
SetSpeed
SetSpeed
Set servo speed in steps per second.
- BYTE ServoID
Servo ID
- UINT Speed
Speed in steps per second (0-3400)
- BOOL Return
SetToolMode
SetToolMode
Set RA3 specific tool mode. Mode: 0=unassigned, 1=vacuum, 2=gripper, 3=pen
- BYTE ServoID
Servo ID
- BYTE Mode
- BOOL Return
SetTorqueLimit
SetTorqueLimit
Set torque limit value (0-1000). Controls maximum torque output.
- BYTE ServoID
Servo ID
- UINT TorqueLimit
Torque limit value (0-1000)
- BOOL Return
StartServo
StartServo
Enable torque (start servo).
- BYTE ServoID
Servo ID
- BOOL Return
StopServo
StopServo
Disable torque (stop servo).
- BYTE ServoID
Servo ID
- BOOL Return
UnlockEEPROM
UnlockEEPROM
Unlock EEPROM to allow writes to be saved after power loss.
- BYTE ServoID
Servo ID
- BOOL Return
TX
RX
Use Flow Control
Baud Options
Textual label shown on the component I/O flasher
Selects if the scope traces are automatically added to the data recorder window or not.
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices
Please click here to download the component source project: FC_Comp_Source_ST3215.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ST3215.fcfx
