Component: LED Array (LEDs)
Revision as of 12:08, 2 October 2026 by Wiki bot (talk | contribs)
Version 1.2
Category LEDs
LED Array component
An array of LED indicators equally spaced and complete with labels to indicate their meaning. Embedded can be used to control an 8-bit port or up to 8 individual pins.
Example program which uses the point graph macro and loops to create a knight rider effect using the LED array.
LED KnightRider
Example program which reads an analogue value from an analogue input voltage and displays the reading in Binary on the LED array.
LED Count
LEDs can be wired either active high or active low. The LED Array components have a property allowing you to configure which LED type your using.
LED Resistor Calculator Tool
AllOff
AllOff
Turns off all elements
AllOn
AllOn
Turns on all elements
BarGraph
BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
- BYTE Length
How many items to light up.
LEDOff
LEDOff
Turn off the selected led.
- BYTE Index
Index of the LED to turn on.
LEDOn
LEDOn
Turn on the selected LED.
- BYTE Index
PointGraph
PointGraph
Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range.
- BYTE Index
The LED to show.
WriteValue
WriteValue
Write a number which is presented on the LEDs in binary.
- BYTE Value
Provide a value to be written to the LEDs in binary
Count
The number of LEDs in the array from 1 to 8.
Function
Simulation Only
Output Mode
Port
Polarity
Component Label
Switch layout
Distance between LEDs
Style
Shape
Colour
Label colour
Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Custom Colours
Auto Off Colour
Controls if an off colour is automatically assigned for you. Yes - Generate automatic off colour No - User can set their own off colour
On Colour
Colour of the indicator when switched on
Off Colour
Colour of the indicator when switched off
Please click here to download the component source project: FC_Comp_Source_LED_Array_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_2dgi.fcfx
