Component: Real Time Clock (PCF8563) (Real Time Clock)
Revision as of 12:08, 2 October 2026 by Wiki bot (talk | contribs)
Version 1.1
Category Real Time Clock
Real Time Clock (PCF8563) component
Serial (I2C) Real Time Clock component for PCF8563 device.
Version information
2, 1.1, 11-09-26, ST, Added generic GetDateTimeString macro
GetDate
GetDate
Returns the date as a string DDMMYY
- BYTE Unit
0=Day, 1=Weekday, 2=Month, 3=Year
GetDateTimeString
GetDateTimeString
Reads the current date from the RTC and returns it formatted as a string Uses y-M-d for date entries and h-m-s for time entries, with doubled letters forcing a leading zero.
- STRING Format
The format string (e.g. "yyyy-MM-dd HH:mm:ss" -> "2026-03-21 18:24:58")
- STRING Return
GetTime
GetTime
Returns a unit from the current time
- BYTE Unit
0=Second, 1=Minute, 2=Hour
Initialises the component ready for I2C communications. Checks for a power on reset flag indicating the RTC time/date needs to be set. 0=No POR detected, 1=POR detected
- BOOL Return
ReadRegister
ReadRegister
Read and return the value of the RTC register at the given address
- BYTE address
- BOOL BCDtoDEC
0=Return register value, 1=Convert BCD value to Decimal
SetDate
SetDate
Sets the date from numeric variables
- BYTE day
Range: 1-31
- BYTE weekday
Range: 0-6
- BYTE month
Range: 1-12
- BYTE year
Range: 0-99
SetTime
SetTime
Sets the time from numeric variables
- BYTE Sec
Range: 0-59
- BYTE Min
Range: 0-59
- BYTE Hour
Range: 0-23
WriteRegister
WriteRegister
Write the given data value to the RTC register at the given address
- BYTE address
- BYTE data
- BOOL DECtoBCD
0=Write data to register, 1=Convert Decimal value to BCD
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_RTC_(PCF8563).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RTC_(PCF8563).fcfx
