Component: WebSocketClient ( Comms)
Revision as of 12:08, 2 October 2026 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | MatrixTSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray;" | Category | Comms |} ==WebSocketClient component== A websocket client component which can be used to create a 2-way communications channel with a websocket server. ==Detailed description== ''No detailed description exists yet for this component'' ==Examples== ''<span style="c...")
Author MatrixTSL
Category Comms
Connect
Connect
Connects to the WebSocket server (returns false if already connected)
- BOOL Return
Disconnect
Disconnect
Disconnect from the WebSocket server
SendString
SendString
Sends a string to the connected WebSocket server (returns false in the client is not connected)
- STRING Data
The string data to send
- BOOL Return
Url
The url of a WebSocket server, e.g. ws://127.0.0.1:8080/
Debug
Determines if additional logging information is sent to the JavaScript console
Callbacks
OnOpen
Called when the connection to a WebSocket server is successfully established
OnClose
Called when the WebSocket connection has been lost
OnReceiveString
Called when a string-based WebSocket message is received
OnReceiveArray
Called when an array-based WebSocket message is received
OnError
Called when a WebSocket error occurs
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Websocket.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Websocket.fcsx
