Component: COM Port (Runtime Tools)
Revision as of 10:24, 5 October 2026 by SteveT (talk | contribs) (fixed the source link)
Version 103.11
Category Runtime Tools
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Version information
10, 103.10, 07-04-25, MW, Modified ReceiveArray NumValues from Byte to UInt
11, 103.11, 01-05-25, BR, Changed SendString macro to make it more efficient
ClosePort
ClosePort
Closes the currently open COM port, ending communications and allowing it to be accessed via another application.
ConfigureConsole
ConfigureConsole
- BYTE Status
GetConsoleHandle
GetConsoleHandle
- HANDLE Return
GetProp
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
OpenPort
OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
ReceiveBinary16Bit
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
- BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveBinary32Bit
ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
- BOOL MSBfirst
- BYTE Timeout
- ULONG Return
ReceiveBinaryFloat
ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
- BOOL MSBfirst
- BYTE Timeout
- FLOAT Return
ReceiveByte
ReceiveByte
Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property.
- UINT Timeout
Time to wait for incoming data in milliseconds
ReceiveByteArray
ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE Data
- UINT MaxLength
Max number of bytes to try and read
- UINT Timeout
ReceiveFloat
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
Max time in ms to wait in between bytes
- BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
- FLOAT Return
ReceiveHexNumber
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE Timeout
- BOOL IgnoreData
- BOOL Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG Return
ReceiveINTArray
ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT Data
Array to store the incoming data
- UINT NumValues
Maximum number of values to try and receive
- BOOL MSBfirst
- BYTE Timeout
- INT Return
ReceiveNumber
ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
- BOOL IgnoreData
- LONG Return
ReceiveString
ReceiveString
Attempts to receive a string using the COM port. MaxLength sets the maximum number of bytes that can be received, Timeout is the max time between characters.
- UINT Timeout
- UINT MaxLength
- STRING Return
ReceiveStringWithTermination
Attempts to receive an string using the COM port. Will return if the selected termination characters are received. Returns the number of bytes received.
- UINT Timeout
- UINT MaxLength
- STRING Termination
String to check for to terminate the receive.
- BYTE TerminationLength
- STRING Return
ScanForDeviceID
ScanForDeviceID
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
- STRING HWID
Example: "VID_12BF&PID_0101"
ScanForDeviceIDEx
ScanForDeviceIDEx
Checks to see if a device VID/PID string is present and returns the COM port number, allows multiple devices with the same details to be detected. Returns 0 if device not found.
- STRING HWID
- BYTE SkipCount
0=Returns first match, 1=Returns second match etc.
- BOOL ScanForDevId
0=Scan PID/VID / 1=Scan DeviceID
SendBinary16Bit
SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
- UINT Value
- BOOL MSBfirst
SendBinary32Bit
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG Value
- BOOL MSBfirst
SendBinaryFloat
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
- FLOAT Value
- BOOL MSBfirst
SendByte
SendByte
Sends a single byte to be sent out via the COM port.
- BYTE Data
SendByteArray
SendByteArray
Sends an array of bytes to the COM port.
- BYTE Data
Data byte array to send
- UINT Length
Number of bytes to send
SendFloat
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
- FLOAT Number
SendHexNumber
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG Number
- BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
- BOOL Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SendINTArray
SendINTArray
Transmits an array of 16-bit INT/UINT values via the UART peripheral
- UINT Data
Data to transmit
- UINT NumValues
Number of 16-bit values to send from the array
- BOOL MSBfirst
SendNumber
SendNumber
Sends out a number as an ASCII String from the UART interface.
- LONG Number
SendString
SendString
Sends an string of characters to the COM port.
- STRING Data
SetDTRState
SetDTRState
Allows the DTR signal to be enabled or disabled.
- BYTE State
A value of 0 disables the DTR, 1 or above willl enable the DTR.
SetFlowControl
SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
- BYTE State
A value of 0 disables flow control, 1 or above willl enable flow control.
SetProp
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
Timeout Value
Value to specify what is returned when no incoming receive data is present.
Auto Close
Auto close the port on Sim stop event
New Line Format
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
