API Component.Property.GetValue
Revision as of 19:22, 7 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Gets the value of a property as a string
Class hierarchy
Component
Property
GetValue
HANDLE Handle
The component handle of the property owner
STRING Property
The textual name of the property
STRING
Returns the value of a property as a string
This call gets the value of a property. All properties are stored as strings internally, though this call will allow the value to be returned (and converted) to a variable of any type.
Note it is the expression of the property that is returned. For example, if a property called connection represents port A, reading the value of connection will return the value of port A, where as this call would return the string "$PORTA", which is the stored representation of the property.
In short, referencing the property variable gets the result of the properties expression, while this call gets the expression itself.
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Component.Property.GetValue(handle, "property")
