API File.Buffer.Open
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Opens the existing file as a circular buffer
Class hierarchy
File
Buffer
Open
STRING Filename
The name of an existing file to open
BOOL Write
Set to enable write access
BOOL Monitor
Set to enable monitoring of the file
HANDLE
  • Add to a calculation icon:
    result = ::File.Buffer.Open("filename", true, false)
