API Scope.AddAnalog
Revision as of 11:09, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Adds an input to the stream from an analog channel
Class hierarchy
Scope
AddAnalog
HANDLE StreamH
A handle to a previously created datascope stream
ULONG ChannelIx
A zero based analog channel index
BOOL Subtract
True to subtract from the current stream, else add to the current value
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Scope.AddAnalog(streamh, channelix, false)
