API Panel.Position.RotateAlong
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import API auto-gen)
API contents Rotates the object by the given rotation along an axis
HANDLE Handle
HANDLE Pivot
The coordinates of the rotation center
HANDLE Axis
An axis to align the angles to
FLOAT X_Pitch
The local X degrees to increment by
FLOAT Y_Yaw
The local Y degrees to increment by
FLOAT Z_Roll
The local Z degrees to increment by
  • Add to a calculation icon: ::Panel.Position.RotateAlong(handle, pivot, axis, x_pitch, y_yaw, z_roll)
